Export AUP Projecto to WAV via command line
Hi, I would like to export audacity projects to wav files with a PHP script.
I was thinking of doing so using the command line, as I believe that would be the easiest way to do so ( using the exec or system PHP functions).
Is it possible?
Is there any other (easier) way?
Thanks.
Audacity is designed primarily as a GUI application. For scripting / command line support it is often easier to use a command line application such as SoX http://sox.sourceforge.net/
If you really need to use Audacity for your purpose, then scripting support can be enabled by compiling Audacity from the source code and compiling the optional “mod-script-pipe” module. http://manual.audacityteam.org/man/Scripting Doing this is likely to be a steep learning curve on Windows unless you are already familiar with building C++ programs from source code. http://wiki.audacityteam.org/wiki/Developing_On_Windows
