I’ve recorded a track from a external cd player via the line in from my pc.In the program settings I choose for best quality.
When I export the audio to mp3 the quality is 128kbps.Is ther no more possibility to get a higher quality ?
For best quality, export as WAV.
For better quality MP3, when you select “MP3” as the Export format, click the “Options” button and select higher quality settings. The presets values are recommended as they are optimised by the developers of the MP3 export library.
See: http://manual.audacityteam.org/o/man/file_export_dialog.html
Thanks,It is good pay attention in the new version after using many years 1.2.6,everything is a little different and tools icons are placed on other places but after a while you get used to it
