Hi there,
I recently recorded at 24bit 96khz. How do i export a wav file at 24bit? The only option i get is Wav 16bit? Help appreciated
Thanks
Hi there,
Thanks
Assuming you are on Audacity 2.0.0 (or alpha 2.0.1) and not 1.2.6 then click on the “Save as type” selection box in the Export dialog and select “Other Compressed files” from the drop-down list. Then use the Options button to select your 24-bit.
Audacity will remember your previously used setting - but the bummer is that it just shows as “Other Compressed files” in the dialog box next time you invoke it so you find yourself clicking on the options again to verify to yourself that you’ve got it right.
