Hello,
I generate a signal in Excel and I need somehow to import the signal in numbers (time and amplitudes) from excel or txt file to Audacity. I don’t know how. Is there any possibility how to do that?
If your point values are at regular (equal) time intervals, then you can use “Sample Data Import”: https://manual.audacityteam.org/man/sample_data_import.html
