Every single Audacity file on m computer was simultaneously corrupted.
I was working on a project, about 2:45:00. I had the original Audacity project copied (but not exported into wav yet, foolishly I guess) and saved in another folder. I uploaded 2 of the other wav files just fine. Then I uploaded the 3rd and final track. After it finished loading, Audacity crashed. I was forced to quit the program. When I opened it back up, it offered me the automatic recovery, and I recovered. It froze again. Rinse and repeat a few times, with plenty of time to load. I was eventually forced to tell it to clear the recovered project.
After this point, NONE of my audacity projects would open. It doesn’t matter where they were on my computer. They had all been working just fine literally moments before. I uninstalled Audacity and got the newer version, but nothing changed.
All of my audacity files from over the years, all the unfinished projects and opportunity to modify the old files, is now completely inaccessible. The data files are still seemingly in working order, but the idea of manually putting back together hours and hours and hours of recording in multiple channels in the totally unorganized cluster**** of 6 second clips is next to impossible.
What are my options here?
Here’s the log:
23:18:04: Audacity 2.3.2
23:18:04: Error: Couldn’t find symbol ‘AudacityModule’ in a dynamic library (error 127: The specified procedure could not be found.)
23:18:06: Trying to load FFmpeg libraries…
23:18:06: Trying to load FFmpeg libraries from system paths. File name is ‘avformat-55.dll’.
23:18:06: Looking up PATH environment variable…
23:18:06: PATH = ‘C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ProgramData\Oracle\Java\javapath;c:\program files (x86)\nvidia corporation\physx\common;c:\windows\system32;c:\windows;c:\windows\system32\wbem;c:\windows\system32\windowspowershell\v1.0;c:\program files (x86)\ati technologies\ati.ace\core-static;c:\program files (x86)\toshiba\bluetooth toshiba stack\sys;c:\program files (x86)\toshiba\bluetooth toshiba stack\sys\x64;c:\program files (x86)\amd\ati.ace\core-static;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program Files (x86)\Scrivener;C:\Users\FJCruise\AppData\Local\Microsoft\WindowsApps;’
23:18:06: Checking that ‘’ is in PATH…
23:18:06: FFmpeg directory is in PATH.
23:18:06: Checking for monolithic avformat from ‘avformat-55.dll’.
23:18:06: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: The specified module could not be found.)
23:18:06: Loading avutil from ‘’.
23:18:06: Error: Failed to load shared library ‘.dll’ (error 126: The specified module could not be found.)
23:18:06: Loading avcodec from ‘’.
23:18:06: Loading avformat from ‘avformat-55.dll’.
23:18:06: Error: Failed to load FFmpeg libraries.
23:18:06: Error: Failed to find compatible FFmpeg libraries.
