Error with Blue Snowball
Hey guys, I’m getting this error when I try to record after setting the device to the Snowball:
Error while opening sound device. Please check the recording device settings and the project sample rate.
I’ve looked through the other forums and can’t seem to find an answer that will work.
Please don’t forget to tell us what version of Audacity you are using. See the pink panel at the top of the page.
See http://manual.audacityteam.org/o/man/faq_errors.html#sound_device. You might simply have pulled the cable out, in which case reconnect it and do Transport > Rescan Audio Devices from the Audacity Menu Bar.
