Error when Using Filter Curve/Graphic Eq on multiple songs
Audacity 3.0.2,
Mac - OS X El Capitan 10.11.6
Good Day,
I have a error when try to apply Filter Curve/Graphic Eq to more than one song - when making a mixtape. It freezes on screen to send bug report endlessly.
I am trying attached a screen shot here- however it says the file is too large
Anticipating your response.
Regards,
Jay Vinyls
What exactly are you doing?
Audacity 3.0.2,
Do you mean that you are applying to multiple songs in one long track, or you are applying the EQ to multiple tracks at the same time, or that you are applying the EQ to multiple files (batch processing), or something else?
I can’t see your machine, so I’ve no idea what you are doing unless you explain in sufficient detail.
Use Audacity’s screenshot tool to create the screenshot (see: Screenshot - Audacity Manual)
Then see here for attaching the file to your post: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
