Error using 3.1.0
Windows 10
Audacity 3.1.0
I am suddenly receiving an error when I press the “Record” button. D’loaded 3.0.1 and have used it for several recording with no problem. Rebooted computed then d’loaded a new 3.1.0. Problem remains. Occurs with both a new d’load and when adding to a previously recorded session.
Thanks for your help.
Harold
“timestamp”: 1636074097,
“event_id”: “e441f91fc440184f9a38089870027235”,
“platform”: “native”,
“release”: “audacity@3.1.0”,
“contexts”: {
“os”: {
“type”: “os”,
“name”: “Windows”,
“version”: “10.0.19043”
“exception”: {
“values”: [
“type”: “Error”,
“value”: “Error opening recording device.\nError code: -9997 Invalid sample rate.”,
“mechanism”: {
“type”: “runtime_error”,
“handled”: false
It says “invalid sample rate” in the error - did you try setting Audacity to a different sample rate?
Thanks for the suggestion. Yes, I changed the rate to 32k and 48k, problem continued. Uninstalled 3.1.0 (not all componets were removed) and reinstalled from new d’load. Problem continued. Performed a cold start on new installation. Problem continued.
Checked program source. Was set to line-in (no idea how that happened, duhhhh). Reset to Microsoft pnp device, works. Thanks.
