error opening sound device
…sometimes it works and sometimes not!..I use Windows 8.1, recently reinstalled Audacity 2.1.1, used installer not zip…for example I open a previously created file, press play to hear it…will play once fine…then make a change to the track and receive the error…tried different things I\ have read in the forums…if I can hear it once, can’t be a problem with Realtech speakers (selected for playback) looked for disabled devices etc. hmmm…I had been “saving project” each time I make a change to a trak, then it would play…but that don’t seem to work either anymore…
How much hard drive space do you have? You have symptoms of a computer slowly being strangled.
“Error opening sound device” doesn’t know or care about whether it can access the audio data in your project or not = if not, it would normally just play silence.
I suggest you have a look at http://manual.audacityteam.org/o/man/faq_errors.html#sound_device.
If the problem persists please attach the contents of Help > Show Log… and Help Audio Device Info… . Please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
