Audacity 2.3.1
Mac OS 10.15.3
Help! I’ve lost months of podcast and guests.
I run audacity on Catalina through terminal (the workaround with external Mic issues) and normally leave everything up and running. I moved my desktop from one location to another and opened again with terminal, all worked, no issues, and files recovered.
This morning the WiFi network was having IP problems and I had to change the static IP address (as I am in a secure, in-home hotspot network), the computer unexpectedly restarted and I went to open via terminal again.
This time, when opening Audacity I was receiving messages that read "“Audacity is already running. The system has detected that another copy of Audacity is running. Running two copies of Audacity simultaneously may cause data loss or may cause your system to crash.”
This seemed to clear up when I closed all and then manually reopened from the terminal again, however --now my files won’t open (see screenshot)
At one point this morning before all, I had moved the aup files into a folder on desktop for neat and easy access as I load all podcast episodes.
I’m hopeful that it’s a simple fix and maybe it’s too far from the _data file?
Please help! Thank you so much!!
Lauren
