Error msg. when I try to record
I use Windows 7 and I have the latest version of Audacity 2.0.3.
When I try to record, I get an error msg that says “Error While opening sound device. Please Check input device settings and project sample rate.”
I also have a MIDI keyboard connected to my computer, as I use Sibelius, the music-writing software.
Since I have not used Audacity in a long time, I’m hoping that someone can help me.
Thanks in advance.
Mimi
Moderator note: Shouting removed - plus I removed your email address to prtect you from spam-harvester-bots - you don’t really want a flood of spam.
What are you trying to record from? What “sound device” are you trying to open? (Audacity doesn’t work with MIDI.)
I want to record my keyboard, and/or my voice or another instrument.
Mimi
I have a MIDI keyboard, too. Actually, two of them. Sound does not travel down the MIDI connection. That’s strictly for the piano key control and usually nothing else.
I do it by connecting a cable between the headphone jack on the keyboard to my computer and then run Audacity to record the show.
That’s how I did these two clips.
http://www.kozco.com/tech/piano2.wav
http://www.kozco.com/tech/organfinale.mp3
Rather than write about all possible combinations, which kind of computer do you have? Windows laptop? Do you have sound connections that look like this?
http://www.kozco.com/tech/audacity/pix/PCLaptopSound.jpg
