Error message from Crossfade Tracks effect
If so I am sure Steve would like to see the file(s) you were using for the crossfade when you had the problem. But had you already deleted the old pluginsettings.cfg file?
If you import only the Colorado file then File > Edit Metadata…, is there any metadata that says “Colorado”? What is the full path to the file including subfolders?
I’ll have to check. I’ll let you know.
I’m out of town for several days.
I’ll check when I return and let you know.
Thanks so much for the help.
