Error Log Message
I’m a first time user attempting to recover music on tape via a device that supposedly writes to my (Win-7) pc’s USB port. I installed from the Audacity website the 2.0.0 version of Audacity. When I try to play back a recording I ultimately find the following messages
in Audacity Log. Any clue why?
3:23:11: Audacity 2.0.0
13:23:11: Error: Couldn't find symbol 'MainPanelFunc' in a dynamic library (error 127: the specified procedure could not be found.)
13:23:14: Trying to load FFmpeg libraries...
13:23:14: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
13:23:14: Looking up PATH environment variable...
13:23:14: PATH = 'C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesATI TechnologiesATI.ACECore-Static;C:Program FilesWindows LiveShared;C:Program FilesCommon FilesHPDigital Imagingbin;C:Program FilesHPDigital Imagingbin;C:Program FilesHPDigital ImagingbinQtQt 4.3.3;C:Program FilesQuickTimeQTSystem'
13:23:14: Checking that '' is in PATH...
13:23:14: FFmpeg directory is in PATH.
13:23:14: Checking for monolithic avformat from 'avformat-52.dll'.
13:23:14: Error: Failed to load shared library 'avformat-52.dll' (error 126: the specified module could not be found.)
13:23:14: Loading avutil from 'avutil-50.dll'.
13:23:14: Error: Failed to load shared library 'avutil-50.dll' (error 126: the specified module could not be found.)
13:23:14: Loading avcodec from 'avcodec-52.dll'.
13:23:14: Error: Failed to load shared library 'avcodec-52.dll' (error 126: the specified module could not be found.)
13:23:14: Loading avformat from 'avformat-52.dll'.
13:23:14: Error: Failed to load FFmpeg libraries.
13:23:14: Error: Failed to find compatible FFmpeg libraries.
Please don’t double post. I answered the other one. Koz
