Audacity has been working great for years and was working today.
Will not record stays on pause.
Error: "Latency Correction etting has caused the recorded audio to be hidden before zero. Audacity has brought it back to start at zero.
you may have to use the TIME Shift Tool (<-------> or F5) to drag the track to the right place.
Windows 7 is no longer officially supported, and neither is Audacity 2.1.3.
The current version of Audacity is 2.4.2 - while Windows 7 is not officially supported, users have reported that it works.
Audacity 2.4.2 is available via the Audacity website: Audacity ® | Download for Windows
That sounds like you have accidentally enabled “Sound Activated Recording”. I don’t recall exactly where that setting is in 2.1.3, but it’s probably somewhere in the Transport menu. When you find it, turn it off.
