Error: Internal PortAudio error
When I try to run Adacity I get the following message “Could not find any audio devices. You will not be able to play or record audio. Error: Internal PortAudio error” I have a set of speakers hooked up and a headset mic and my webcam mic None of these are even registering for Audacity although I can record and listen on other programs and websites. I am using Windows 10. I just reinstalled Audacity today and still got the same results. Help Please.
Please see the Windows 10 help page: http://wiki.audacityteam.org/wiki/Windows_10_OS.
I encounter the same error. I’m running Windows 10 on an MS-Z68 64 bit Intel core i5-2500K with Realtek High Def Audio. I understand what you are saying about Windows 10 drivers, but Audacity 2.0.1 runs fine. It is only when I upgraded to Audacity 2.1.2 that it could not find any device drivers. The recommendation has been to go back to windows 7, but an equally good solution seems to be to go back to Audacity 2.0.1 (2.0.6 doesn’t work either). Maybe whatever 2.0.1 is doing could be put in 2.1.2.
The Windows 10 Wiki page is clear that you can go back to Audacity 2.0.3.
We hope to be updating the PortAudio audio I/O library that we use, which has some fixes that may help. Then we can see if more needs to be done by us.
Would you like to help us test those changes when made?
OK, sure, I’m in. Can’t complain without offering to help…
Please see Testing requested on Windows 10 for PortAudio Errror for a build you can test.
Thanks for your help.
To those who are having the same issue:
Here’s a video from Youtube and this is the real workaround/resolution.
Hope this will help you.
Go to the link below.
https://youtu.be/Ml_lxjk1ZeE
It looks like the underlying problem on your system is the “Droidcam virtual audio device”.
Is it sufficient to just disable all of the Droidcam entries before launching Audacity?
I can’t find out what is the final solution?
Why are you writing replies like this all over the forum?
