Error: Failed to load shared library 'avformat-60.dll' (error 126: Cannot find the specified module.)
16:38:07: Audacity 3.4.2
16:38:07: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Cannot find the specified module.)
16:38:07: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Cannot find the specified module.)
16:38:07: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Cannot find the specified module.)
16:38:07: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Cannot find the specified module.)
16:38:07: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Cannot find the specified module.)
16:38:21: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
16:38:21: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Cannot find the specified module.)
16:38:21: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Cannot find the specified module.)
16:38:21: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Cannot find the specified module.)
16:38:21: Error: Failed to load shared library ‘avformat-57.dll’ (error 126:Cannot find the specified module.)
16:38:21: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Cannot find the specified module.)
16:38:27: Using internal LAME
16:38:27: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Cannot find the specified module.)
16:38:27: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Cannot find the specified module.)
16:38:27: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Cannot find the specified module.)
16:38:27: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Cannot find the specified module.)
16:38:27: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Cannot find the specified module.)
16:38:32: Help button pressed: PageName FAQ:Installing_the_FFmpeg_Import_Export_Library, releasePageName faq_installing_the_ffmpeg_import_export_library.html
16:38:32: webHelpPage FAQ:Installing the FFmpeg Import/Export Library - Audacity Manual, localHelpPage C:\Program Files\audacity\help\manual\man\faq_installing_the_ffmpeg_import_export_library.html
16:57:58: Help button pressed: PageName FAQ:Installing_the_FFmpeg_Import_Export_Library, releasePageName faq_installing_the_ffmpeg_import_export_library.html
16:57:58: webHelpPage FAQ:Installing the FFmpeg Import/Export Library - Audacity Manual, localHelpPage C:\Program Files\audacity\help\manual\man\faq_installing_the_ffmpeg_import_export_library.html
17:00:55: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: Cannot find the specified module.)
17:00:55: Error: Failed to load shared library ‘avformat-59.dll’ (error 126: Cannot find the specified module.)
17:00:55: Error: Failed to load shared library ‘avformat-58.dll’ (error 126: Cannot find the specified module.)
17:00:55: Error: Failed to load shared library ‘avformat-57.dll’ (error 126: Cannot find the specified module.)
17:00:55: Error: Failed to load shared library ‘avformat-55.dll’ (error 126: Cannot find the specified module.)
17:00:55: Looking for FFmpeg libraries…
17:01:52: User-specified path = ‘C:\Program Files\ffmpeg-6.1.1-full_build-shared\bin’
17:01:59: FFmpeg libraries loaded successfully from: C:\Program Files\ffmpeg-6.1.1-full_build-shared\bin\avformat-60.dll
17:01:59: User-specified FFmpeg file exists. Success.
17:02:01: Using internal LAME
17:02:01: FFmpeg libraries loaded successfully from: C:\Program Files\ffmpeg-6.1.1-full_build-shared\bin\avformat-60.dll
17:02:47: Error: In Music Generation, exception: If num_output_segments is set, it must be <= num_interpolation_steps
17:02:48: Operation ‘OpenVINO Music Generation’ took 2.608000 seconds. Poll was called 6 times and took 0.026330 seconds. Yield was called 6 times and took 0.010446 seconds.
