Error code 9987
I have a yeti microphone and I keep getting the error 9986. My sample rate is set to 44100 so does anyone know any trouble shooting steps I can make? Thank you
From the manual:
(Error opening sound device - Audacity Manual)
9996 Invalid device: > this means that the sound device is not valid, if it is an external sound device:
  •    it may have been unplugged
  •    you may have a faulty or loose connection
  •    you may have a bad lead
  •    the device itself may be faulty.
