Error building 2.2.2 in 64-bit
I switched to 64-bit (Slackware 14.2, updated daily, kernel 4.17.1, self-built). I downloaded the latest Audacity (2.2.2-rc1) When I build I get:
In file included from gtk/FileDialogPrivate.cpp:23:0:
/usr/local/include/wx-3.0/wx/filename.h: In static member function ‘static wxUniChar wxFileName::GetPathSeparator(wxPathFormat)’:
/usr/local/include/wx-3.0/wx/filename.h:473:43: error: ambiguous overload for ‘operator[]’ (operand types are ‘wxString’ and ‘unsigned int’)
{ return GetPathSeparators(format)[0u]; }
/usr/local/include/wx-3.0/wx/filename.h:473:43: note: candidate: operator[](const char*, long int)
/usr/local/include/wx-3.0/wx/filename.h:473:43: note: candidate: operator[](const wchar_t*, long int)
In file included from /usr/local/include/wx-3.0/wx/filectrl.h:19:0,
from gtk/…/FileDialog.h:21,
from gtk/FileDialogPrivate.cpp:14:
/usr/local/include/wx-3.0/wx/string.h:1544:15: note: candidate: wxUniChar wxString::operator const
wxUniChar operator[](int n) const
/usr/local/include/wx-3.0/wx/string.h:1546:15: note: candidate: wxUniChar wxString::operator[](long int) const
wxUniChar operator[](long n) const
/usr/local/include/wx-3.0/wx/string.h:1548:15: note: candidate: wxUniChar wxString::operator const
wxUniChar operator[](size_t n) const
/usr/local/include/wx-3.0/wx/string.h:1556:18: note: candidate: wxUniCharRef wxString::operator
wxUniCharRef operator[](int n)
/usr/local/include/wx-3.0/wx/string.h:1558:18: note: candidate: wxUniCharRef wxString::operator[](long int)
wxUniCharRef operator[](long n)
/usr/local/include/wx-3.0/wx/string.h:1560:18: note: candidate: wxUniCharRef wxString::operator
wxUniCharRef operator[](size_t n)
make[2]: *** [Makefile:585: gtk/libFileDialog_la-FileDialogPrivate.lo] Error 1
make[1]: *** [Makefile:1013: all-recursive] Error 1
make: *** [Makefile:808: all-recursive] Error 1
Is this a wxWidgets problem? I can’t build it either.
Are you saying that you don’t have a working version of WxWidgets?
I had a working version of wxWidgets. It seemed to be the current version the first place I looked. I downloaded the source anew but still couldn’t build. More searching turned up version 3.04 which I could build, then I could build Audacity. Apologize for my bungling.
