error 1020
Getting an error 1020 when trying to add the FFMpeg
Error 1020 Ray ID: 6acc26c5dec870be • 2021-11-12 01:57:46 UTC
Access denied
What happened?
This website is using a security service to protect itself from online attacks.
Any help would be appreciated
It could just be a glitch on the server. If it is, then just try again later.
Another possibility is that your IP may be black listed for some reason. If you use an adsl line, then your IP address is likely to change over time - how often it does this depends on your ISP (Internet Service Provider). Turning off the ADSL modem for an hour and then back on again will often give you a new IP address. You can check your public IP address on this site: https://whatismyipaddress.com/ (there are others).
