Erreur de recuperation de projet suite au redemarrage du pc
Bonjour
Ayant récemment fait un enregistrement audio avec la version audacity 1.3 unicode sur windows seven, un redemarrage ( plantage ) de windows a eu lieu pendant l’enregistrement. Apres le redemarrage audacity me propose de recuperer le projet mais m’affiche : erreur : not well-formed (invalid token) à la ligne 9667"
Pouvez-vous m’aidez a recuperer le projet ?
Merci d’avance
Bonjour,
je transmets à l’assistance internationale.
Cordialement
Do you get that error when 1) the Automatic Crash Recovery dialogue appeared, or 2) were you trying to open the .aup file?
You need to open the autosave file if the problem is automated crash recovery or otherwise open the .aup file, turn wordwrap off and look at line 9667 for malformed or unclosed tags. You can attach the .aup or .autosave file if you need help. The autosave file on Vista or 7 is at UsersAppDataRoamingAudacityAutoSave. The autosave file won’t exist any longer if you closed the project. You also have to show hidden files and folders to see AppData:
http://www.bleepingcomputer.com/tutorials/tutorial151.html .
Also if Windows crashed you must update sound device drivers and/or look at the crash dump to identify the problem to stop it happening again. This (still rather rough) FAQ may help:
http://manual.audacityteam.org/man/FAQ_-_Error:_computer_rebooting_when_I_play_or_record_in_Audacity .
