Equivalent of SetTrackAudio: Volume in sox
Hello there,
I am finding an equivalent command of SetTrackAudio: Volume in sox CLI, btw I am using mod-script-pipe to communicate with audacity. I have found one command which is gain but it seems the equivalent of amplification in audacity(Amplify: Ratio in case of using it via mod-script-pipe), amplification in audacity and gain in sox changes the shape of the waveform but SetTrackAudio Volume does not change the shape of the waveform, it will be really helpful if someone can guide on this, also it will be good to know the difference between amplification and Volume in audacity as one operation changes the shape of the waveform while the other does not.
