Equalizer Graphics
I have transferred this FR and its vote to the Wiki today 14Jul08 - but retained this thread in the Forum, but relocated to Audio Processing - WC
This one should be pretty harmless.
I want pinstripes inside the equalizer work window to tell me where I am. Quick, point to a place 4 dB down at 7500 Hz.
No, I can’t do it, either, although I need to do it because that’s part of a complex curve I want to build. A much harder version of this involves two windows that read out the cursor position, similar to what happens in the analyzer. That would be a programming pain in the butt.
Either one would be welcome.
Check out the file “EQCurves.xml”
I’m not sure where it will be on a Mac, but in Linux it’s: home//.audacity-data/EQCurves.xml
They can be as simple or complex as you like. They can be edited directly and they are probably transportable.
Try copy and pasting these curve into your “EQCurves.xml” file:
	<curve name="ska">
		<point f="20.00" d="-15.0"/>
		<point f="25.00" d="-2.9"/>
		<point f="30.00" d="2.6"/>
		<point f="40.00" d="4.8"/>
		<point f="50.00" d="5.0"/>
		<point f="60.00" d="5.0"/>
		<point f="80.00" d="3.0"/>
		<point f="100.0" d="0.8"/>
		<point f="120.0" d="-0.9"/>
		<point f="150.0" d="-2.5"/>
		<point f="200.0" d="-5.0"/>
		<point f="300" d="-8.4"/>
		<point f="400" d="-10.0"/>
		<point f="600" d="-8.0"/>
		<point f="1200" d="-2.0"/>
		<point f="1300" d="1.05"/>
		<point f="1400" d="-2.0"/>
		<point f="1500" d="-4.0"/>
		<point f="1600" d="-4.0"/>
		<point f="2000" d="-8.0"/>
		<point f="3000" d="-2.5"/>
		<point f="4000" d="2.0"/>
		<point f="6000" d="4.0"/>
		<point f="10000" d="4.0"/>
		<point f="18000" d="0.8"/>
		<point f="24000" d="0.0"/>
	</curve>
or a simple one
	<curve name="slope">
		<point f="20" d="-15"/>
		<point f="800" d="-10"/>
		<point f="2000" d="-5"/>
		<point f="10000" d="0"/>
		<point f="24000" d="5"/>
	</curve>
or a high precision one
<curve name="stevethefiddle">
		<point f="20.000000000000" d="-15.250000000000"/>
		<point f="20.808085587751" d="-14.828845528587"/>
		<point f="21.648821291359" d="-13.210369678949"/>
		<point f="22.523526315227" d="-10.421537752467"/>
		<point f="23.433573165260" d="-7.506270226987"/>
		<point f="24.380389802479" d="-5.000612646688"/>
		<point f="25.365461883636" d="-2.878729210669"/>
		<point f="26.390335092377" d="-1.143066633971"/>
		<point f="27.456617564581" d="0.151825562244"/>
		<point f="28.565982411698" d="1.077789612328"/>
		<point f="29.720170346040" d="1.881386973913"/>
		<point f="30.920992412148" d="2.583268093849"/>
		<point f="32.170332828509" d="3.102141977255"/>
		<point f="33.470151944103" d="3.542030752102"/>
		<point f="34.822489314397" d="3.909475294480"/>
		<point f="36.229466901626" d="4.210700032747"/>
		<point f="37.693292404382" d="4.462668429028"/>
		<point f="39.216262721726" d="4.666340670329"/>
		<point f="40.800767557271" d="4.830937750120"/>
		<point f="42.449293168882" d="4.945400395213"/>
		<point f="44.164426269882" d="4.996846125663"/>
		<point f="45.948858087882" d="5.000000000000"/>
		<point f="47.805388587604" d="5.000000000000"/>
		<point f="49.736930864329" d="5.000000000000"/>
		<point f="51.746515714852" d="5.000000000000"/>
		<point f="53.837296393127" d="5.000000000000"/>
		<point f="56.012553558067" d="5.000000000000"/>
		<point f="58.275700421238" d="4.973853617362"/>
		<point f="60.630288102564" d="4.889769745216"/>
		<point f="63.080011202408" d="4.747852733618"/>
		<point f="65.628713598801" d="4.555235043702"/>
		<point f="68.280394478894" d="4.308322783647"/>
		<point f="71.039214614112" d="4.007122899922"/>
		<point f="73.909502888854" d="3.678153390726"/>
		<point f="76.895763092971" d="3.346263433819"/>
		<point f="80.002680988700" d="3.011432950309"/>
		<point f="83.235131663122" d="2.649756226695"/>
		<point f="86.598187177699" d="2.284732287898"/>
		<point f="90.097124526884" d="1.916517687132"/>
		<point f="93.737433918284" d="1.551122496975"/>
		<point f="97.524827387392" d="1.191623919953"/>
		<point f="101.465247760377" d="0.838021956066"/>
		<point f="105.564877979016" d="0.490316605314"/>
		<point f="109.830150802394" d="0.148507867696"/>
		<point f="114.267758900593" d="-0.188892244184"/>
		<point f="118.884665356203" d="-0.529225458909"/>
		<point f="123.688114590153" d="-0.873484348831"/>
		<point f="128.685643728974" d="-1.196999455758"/>
		<point f="133.885094431369" d="-1.514860930285"/>
		<point f="139.294625192605" d="-1.835930013061"/>
		<point f="144.922724146073" d="-2.160310658875"/>
		<point f="150.778222382078" d="-2.488404350321"/>
		<point f="156.870307804764" d="-2.820250990771"/>
		<point f="163.208539548921" d="-3.173835531941"/>
		<point f="169.802862979293" d="-3.549697551976"/>
		<point f="176.663625295917" d="-3.930152669947"/>
		<point f="183.801591769993" d="-4.309858134833"/>
		<point f="191.227962635747" d="-4.672483920902"/>
		<point f="198.954390664797" d="-5.016894619758"/>
		<point f="206.992999450601" d="-5.343090231399"/>
		<point f="215.356402431673" d="-5.651070755826"/>
		<point f="224.057722683423" d="-5.940891062086"/>
		<point f="233.110613509667" d="-6.235809959491"/>
		<point f="242.529279866118" d="-6.554935638023"/>
		<point f="252.328500649494" d="-6.895400605699"/>
		<point f="262.523651887182" d="-7.249676472032"/>
		<point f="273.130730863876" d="-7.626518712358"/>
		<point f="284.166381223030" d="-8.022872881405"/>
		<point f="295.647919082519" d="-8.395097889039"/>
		<point f="307.593360205482" d="-8.728971249350"/>
		<point f="320.021448268984" d="-9.020896172488"/>
		<point f="332.951684274858" d="-9.270777421888"/>
		<point f="346.404357148860" d="-9.484764404471"/>
		<point f="360.400575576173" d="-9.663127261308"/>
		<point f="374.962301123193" d="-9.808568867676"/>
		<point f="390.112382697579" d="-9.921786244100"/>
		<point f="405.874592400641" d="-10.004453978460"/>
		<point f="422.273662828311" d="-10.054551206102"/>
		<point f="439.335325879237" d="-10.067715250055"/>
		<point f="457.086353130889" d="-10.045360478063"/>
		<point f="475.554597847034" d="-9.994443174966"/>
		<point f="494.769038682487" d="-9.915900374063"/>
		<point f="514.759825153732" d="-9.812761512598"/>
		<point f="535.558324946738" d="-9.684715855885"/>
		<point f="557.197173136223" d="-9.530916782724"/>
		<point f="579.710323393581" d="-9.350155918295"/>
		<point f="603.133101263832" d="-9.140082362104"/>
		<point f="627.502259595185" d="-8.900635564251"/>
		<point f="652.856036208198" d="-8.640110081676"/>
		<point f="679.234213895013" d="-8.352923686697"/>
		<point f="706.678182842822" d="-8.038246139522"/>
		<point f="735.231005579501" d="-7.706821634408"/>
		<point f="764.937484543336" d="-7.375212513928"/>
		<point f="795.844232382847" d="-7.043603393448"/>
		<point f="827.999745097028" d="-6.691668267706"/>
		<point f="861.454478130761" d="-6.336655832309"/>
		<point f="896.260925544827" d="-5.981682344187"/>
		<point f="932.473702384699" d="-5.642743688705"/>
		<point f="970.149630377408" d="-5.332939668016"/>
		<point f="1009.347827090922" d="-5.052270282123"/>
		<point f="1050.129798695936" d="-4.800735531023"/>
		<point f="1092.559536475655" d="-4.578335414719"/>
		<point f="1136.703617234967" d="-4.388720609166"/>
		<point f="1182.631307766587" d="-4.262936692435"/>
		<point f="1230.414673538071" d="-4.208055049372"/>
		<point f="1280.128691770264" d="-4.221220544422"/>
		<point f="1331.851369084591" d="-4.293011444200"/>
		<point f="1385.663863903797" d="-4.422735490879"/>
		<point f="1441.650613798221" d="-4.611609426064"/>
		<point f="1499.899467977380" d="-4.867386265049"/>
		<point f="1560.501825134801" d="-5.191436659110"/>
		<point f="1623.552776862353" d="-5.600535276583"/>
		<point f="1689.151256859160" d="-6.117062241804"/>
		<point f="1757.400196169156" d="-6.717146730572"/>
		<point f="1828.406684690938" d="-7.355813158095"/>
		<point f="1902.282139213286" d="-7.812561327004"/>
		<point f="1979.142478240037" d="-8.057797608654"/>
		<point f="2059.108303878647" d="-8.091522003043"/>
		<point f="2142.305091077818" d="-7.913734510172"/>
		<point f="2228.863384511134" d="-7.524435130041"/>
		<point f="2318.919003415637" d="-6.984213921538"/>
		<point f="2412.613254706779" d="-6.375635660368"/>
		<point f="2510.093154704097" d="-5.701668113256"/>
		<point f="2611.511659815581" d="-4.984351889985"/>
		<point f="2717.027906542657" d="-4.203755352873"/>
		<point f="2826.807461182420" d="-3.361971843810"/>
		<point f="2941.022579618894" d="-2.539133580825"/>
		<point f="3059.852477610953" d="-1.776227979000"/>
		<point f="3183.483612001085" d="-1.079108352158"/>
		<point f="3312.109973286116" d="-0.455562256503"/>
		<point f="3445.933390009112" d="0.111891361228"/>
		<point f="3585.163845449983" d="0.624155963216"/>
		<point f="3730.019807111749" d="1.100914198321"/>
		<point f="3880.728569519447" d="1.550181281231"/>
		<point f="4037.526610869621" d="1.978742246349"/>
		<point f="4200.659964089935" d="2.399325435265"/>
		<point f="4370.384602891188" d="2.788400166859"/>
		<point f="4546.966843417520" d="3.145966441131"/>
		<point f="4730.683762124962" d="3.472024258082"/>
		<point f="4921.823630544081" d="3.766573617711"/>
		<point f="5120.686367608909" d="4.024473938388"/>
		<point f="5327.584010261886" d="4.249179726607"/>
		<point f="5542.841203073237" d="4.444512273164"/>
		<point f="5766.795707643121" d="4.610471578059"/>
		<point f="5999.798932585757" d="4.747057641292"/>
		<point f="6242.216484927173" d="4.854270462863"/>
		<point f="6494.428743781841" d="4.930522577626"/>
		<point f="6756.831457208243" d="4.978583382957"/>
		<point f="7029.836363179988" d="4.999153036092"/>
		<point f="7313.871835646775" d="4.992231537030"/>
		<point f="7609.383556699107" d="4.957818885772"/>
		<point f="7916.835215891137" d="4.895915082318"/>
		<point f="8236.709237819316" d="4.801124311446"/>
		<point f="8569.507539098324" d="4.673421289623"/>
		<point f="8915.752315921907" d="4.514209810480"/>
		<point f="9275.986863444756" d="4.336806012751"/>
		<point f="9650.776428270770" d="4.159299795052"/>
		<point f="10040.709095385559" d="3.981793577354"/>
		<point f="10446.396710924804" d="3.804287359655"/>
		<point f="10868.475842226373" d="3.626781141956"/>
		<point f="11307.608776672689" d="3.449274924258"/>
		<point f="11764.484560890680" d="3.271768706559"/>
		<point f="12239.820081939626" d="3.094262488861"/>
		<point f="12734.361192183844" d="2.924753725134"/>
		<point f="13248.883879615034" d="2.764301017958"/>
		<point f="13784.195485460406" d="2.603848310783"/>
		<point f="14341.135970987791" d="2.441793574762"/>
		<point f="14920.579235494641" d="2.259386003328"/>
		<point f="15523.434487549899" d="2.051233360653"/>
		<point f="16150.647671639461" d="1.811122139457"/>
		<point f="16803.202952454511" d="1.521653799616"/>
		<point f="17482.124259151475" d="1.200677002453"/>
		<point f="18188.476892006398" d="0.856520692338"/>
		<point f="18923.369193985294" d="0.559470809758"/>
		<point f="19687.954289853158" d="0.325437841822"/>
		<point f="20483.431895550038" d="0.154421788529"/>
		<point f="21311.050200674003" d="0.046422649880"/>
		<point f="22172.107827024505" d="0.001440425874"/>
		<point f="23067.955866278819" d="0.000000000000"/>
		<point f="24000.000000000018" d="0.000000000000"/>
	</curve>
Goodness.
I’m out of breath. I’ll have to sit down for a minute.
I’ve been thinking about this suggestion every time I use the Equalization effect (and the “plot spectrum”) and yes I agree, a “graph paper background” would be very handy. It would be nice if the background could be toggled on/off.
