I use Macros to create voice processing ‘recipes’ - for example, a combination of EQ and compression.
However, the problem is with the EQ. I can’t get Audacity to remember my EQ setting (I have it saved in User Presets). I have even tried ‘Edit Parameters’ but it still doesn’t remember my EQ setting.
The EQ seems to be ‘stuck’ on a previous setting.
I had this issue last year, and I heard this was an issue others were having too. However, the last update didn’t fix this (or have I done something wrong?)
Thanks so much for all your work with Audacity. I hope this can be easily solved.
Yes, we are hoping to fix this and other EQ bugs for the next release - and we may be spliiting EQ into two separate effects rather than switching modes within the effect.
If this is the same problem, I have a more devious way. Audacity will save Last Curve Changed. So get yourself a curve in Draw mode. Doesn’t matter how you get there. Make one super tiny change anywhere in the curve. That curve will now stick until the sun cools off.
See that one tiny dot at 1000Hz? It doesn’t actually do anything to the sound, but that’s how I got the Audiobook mastering curve to stick. It’s been there for weeks.
But that curve will be lost as soon as you use the Equalization effect with different settings. That’s the purpose of saving the settings with a name. Named presets exist until you delete them.
It’s true. Those different settings will come back, not the original.
But if you go away to a named setting, Audacity will snap back to the last changed. That was the problem I had. That’s still not a bad, quick way to make a curve sticky.
I note that point by point managing an equalization correction; and running a batch, sorry, chains, sorry, macros tend to be on opposite ends of the production process.
