hello
how to use volume change on two track with enveloppe tool ?
bonjour
comment utiliser " volume change " sur deux pistes avec l’outil enveloppe
merci
hello
bonjour
merci
The envelope only acts on the track to which it is applied.
Envelopes cannot currently be copied separately from the audio.
So the only way to apply an envelope to two tracks is to draw two envelopes; one on each track.
hello
sorry did i understand correctly .
" So the only way to apply an envelope to two tracks is to draw two envelopes; one on each track "
so an envelope only apply for the track selected ! mono or stereo
thanks
Yes envelopes can be applied to mono or stereo tracks, but the envelope only applies to one track.
