hello
first bravo ! for all for the previous help !
how to use " envelope tool " on the [ say the two left side ]
of two stereo to mono splited track ?
bonjour
premieremment bravo pour tout les depannages precedant !
comment utiliser " envelope tool " sur les [ deux cote gauches ]
de 2 stereo pistes transformer en mono piste ?
merci beaucoup / thanks a lot .
Do you mean how to make Envelope Tool add the same envelope points to both left channels at the same time? It cannot, unless you trick it by moving the left channel of the second track up (so that is underneath the left channel of the first track) then “Make Stereo Track” on the first track at the top.
Split the track you applied Envelope to when you are finished, then move the second track back down to track three.
Also read http://manual.audacityteam.org/help/manual/man/envelope_tool.html ( or in French http://manual.audacityteam.org/man/Envelope_Tool/fr ).
whaoo ! its a good trick i will do it that way
thanks a lot cale
