Envelope Tool Extended Amplitude [SOLVED]
Hi
When I zoom out vertically I cannot see any change in the amplitude range as in manual. Mine just stays at 1.0 regardless of how far I zoom out.
Am I missing something?
And my vertical zoom out:
Thanks
J
Which version of Audacity are you using? (Look in “Audacity menu > About Audacity”.)
It’s latest:2.3.2
Thanks J
You’ve not actually “zoomed out”, you have just made the track vertically “bigger”. To zoom out vertically, right click on the track’s vertical ruler and select “Zoom x 1/2” from the drop-down menu.
Thanks Steve - I tried that on a new project and it now works. Not sure what was happening. Thanks
