What are the steps for emailing an Audacity audio file? Is there a particular format that it has to be “saved” in first?
Thanks!
Ben
Thanks!
Ben
Audacity has no e-mail feature, you can only export the file.
Given e-mail services often have attachment limits, and given you may not know the limits on the service your recipient is using, it’s often better to use Dropbox or similar.
See Sending your work to others.
