ELEVAYTA EXTRA BOY PRO ALTERNATIVE
WINDOWS 7 64-BIT - AUDACITY 2.0.5 - EXE FILE INSTALLER
I’ve been experimenting with Extra Boy Pro from Elevayta over the past two weeks for isolating individual sounds within an overall mix, and I’m not at all impressed. I really do question whether this program can actually do what it claims to, since all it seems to produce is a region which gives a variant of the song in a full spectrum capacity - but seems thoroughly incapable of actually filtering out the unwanted components and seperating a specific element as it claims. Is trying to acheive what the developer says it can on the website a realistic goal - and if so, can someone please recommend a proper alternative to this seemingly useless sack of crap?
Thanks In Advance - SIMON
It is a difficult task, and the degree of success is highly dependent on the type of source material. (The demo’s on their site show “best case” results).
Robert J. H. posted an experimental tool that may be of interest. Refer to the notes in this topic for downloading and how to use. I know no more about it than is written there, but if you have questions about the tool then Robert may be able to help (he still visits the forum fairly regularly).
