I have windows 10, and I’m trying to record a Roland kit onto audacity using a Behringer u-phoria um22 to tie it all in…
Now,I can hear the guitar tracks that have been recorded & I can also hear the kit when I play it but when I press to record it doesn’t record the kit…
It should light up green then yellow etc on Audacity when I hit the kit but it’s not showing up tho on the UM22 the levels are showing…
INST 2 will only be recorded by Audacity if you are recording 2 channels (stereo). When recording 1 channel (mono) Audacity will record only the first input of the device (marked “Mic / Line 1” on the UM2). Note that “Mic / Line 1” can accept a 3 pin XLR or a 1/4" jack plug.
You should be able to get a good strong signal into Audacity.
Ensure that the Roland is turned well up, then gradually increase the input level for mic/line 1 until the red “clip” LED just starts to come on, then back off the input level a little so that the clip LED does not come on.
When you’ve got the level set there, check the level in Audacity. Ideally you will be peaking just a little over half the track height (-6 dB) but must remain under 0 dB at all times.
