Effects settings won’t save. The dialogue box opens; I click to save, but the folder shows empty afterwards, other than the subfolders that are already there.
Please read the pink panel at the top of the page and give us the required information.
Which effect(s) exactly are you talking about? Are you talking about the Manage button in an effect, then exporting a preset?
As a wild guess, try adding the extension that is required to the name. So if you are saving an XML file, add
.xml
to the end of the file name.
Thank you Gale. I needed to add the .fxp.
