Effect templates?
Is there a way to lessen the burden of having to apply the same series of effects on every next audio recording I make?
For example I make a recording then apply effects in succession like: A B C B D E (the letters representing different effects)
Can I somehow tell the application to apply those same effects in the same order on the next recording? or do I have to apply them manually every time?
See these two pages:
http://manual.audacityteam.org/man/Edit_Chains
http://manual.audacityteam.org/man/Apply_Chain
Note that there are some restrictions on what can be done with Chains, but hopefully this will help to take out some of the repetition.
Aha! Seems like that was indeed what I was looking for.
Hopefully this will save me a bunch of time, many thanks.
