Hi there, I have downloaded the newest version of Audacity for windows, but most of the options under the effect tab are grayed out. The plug-in manager shows them as enabled when I look there, but they remain grayed out. What do I need to do?
Make sure that the audio is stopped before applying effects.
Thank you all for your comments. I did get it from the Audacity website and have version 2.3.3 for Windows. I will follow your suggestions to see if that takes care of the issue. Many thanks to you all for responding.
