How weird - in the pitch & tempo menu under “effect,” there is no tempo dialog - just pitch, paulstretch, and sliding stretch. Developers, please add that back!! Thank you!!
This feature hasn’t made it into Audacity 4.0 and may be added to a future version. In the meantime, I have added it to Soundscaper, my web version of Audacity 4.
Yes, add it back. Why are they deleting these thigs
They’re not deleting them, they just haven’t gotten around to implementing them yet.
I don’t know how I missed this, but if you right-click on a clip you get a context menu containing the item “Open pitch and speed dialog” where you can independently set the pitch and speed. This is non-destructive but you can render the change through the same context menu, as well as reset it.
