Effect factors, in adding quotes to commands?
I am adding quotes just after command audio file.
What is the most important factors, in processing a quote, so it does not seem out of place with the commands audio file?
Should it use the same compression, expansion, or equalization, that the commands audio uses. Or does that matter?
I think that you will need to give a bit more background to what you are doing.
What are these “commands” and “quotes” that you are speaking of?
Is this for some sort of automation project? or a game?
