Effect errors?
I’m getting an error box (like attached) about every time I try to use a new or different effect it seems. Looks to be that the next effect I choose is trying to use the default data from the last one?
The errors don’t seem to effect anything as the effect then opens normally and works fine. Just thought I’d find out if its a bug or something I have set up wrong. I do notice that in manage effects there are 2 Nyquist prompts, but 1 or both keep coming up disabled even if I enable them. The VST-bridge always says NEW even after enabling it also.
Thanks much!
Ken
It should not happen more than once for each effect.
It’s a side effect of the effect settings being updated.
Opps, didn’t see you there. Thanks Steve!
