Effect applied to multiple clips
Please help,
When I apply an effect to one selected clip it then automatically merges with some neighbouring clips and applies the effect. How do I fix this? I only want to apply the effect to the selected clip. Funnily enough it doesn’t do it with things like amplify. But with noise reduction and EQ effects.
Thanks guys!
This is a known bug Applying Nyquist effect to a clip merges the clip with adjacent clips · Issue #11144 · audacity/audacity · GitHub
It applies only to Nyquist effect.
There’s a pull request for a fix but it apparently didn’t make it into 4.0.1.
Thanks! At least means, I’m not going crazy trying to figure out what I’m doing wrong :laughing:
