Cannot seem to find the documented EditMetaData operation in the available Macro function list.
Would like to eliminate a meta data field before saving in Batch (Files) mode.
Program build date: Feb 24 2019
Commit Id: 1c21e9 of Sun Feb 24 08:28:05 2019 +0000
Build type: Release build
Compiler: MSVC 19.14.26431.00
The EditMetaData: command is not available in the list of Macro commands, and in its current form it would not be useful. All that the command does is to open the Metadata Editor - it does not provide a means to modify the metadata with a macro, you would still have to do that manually.
For batch processing metadata, I’d suggest using a specialist “tag editor” such as Mp3Tag (https://www.mp3tag.de/en/), or use the tag editing features of your favourite media player.
