Hello everyone,
I am currently making a remix of some LotR music, but when I join tracks together there are audible ticks where there is an abrupt change in amplitude. In Waveform (dB) View these changes are clearly visible, but when required to edit the tracks in Waveform view the draw tool is not able to make fine enough adjustments. Track in Waveform (dB) view.
Is there any way I can make any finer adjustments to the Waveform track, or to edit the track in Waveform (dB) view?
Thanks,
Echo
Yes, just zoom in - I would recommend zooming in until you can begin to see the individual sample points (show as little dots on the waveform) - see this page in the manual: http://manual.audacityteam.org/o/man/edit_toolbar.html#zoomin
You can see what I mean here: https://forum.audacityteam.org/t/smoothing-out-spikes-in-db-waveform/35033/1
as I dont think you understood what I meant. Thanks, echo.
