Hi,
I’m trying to capture one track out of many tracks I digitized all as one file.
Is there a way to fast forward while listening to the track?
I looked in Help and didn’t see anything for fast forwarding.
In VLC Media once you have a track you’re listening to if you want to reach the end of that track (and you’re guessing where it ends) you can grab the slider and slide it to where you think is near the end of that track.
I’m also grappling with how to (easiest way) capture just one track and save that track as its own file.
The track I’m trying to capture is at the beginning of the entire digitized recording. So, I have to listen to it several times to see exactly where the music begins. Then, I press the Home key and then I hold down the Shift key and press A as soon as I hear music start.
I would then like to reach the end of the track but I can’t seem to listen to it and drag the slider at the same time.
I’ve tried “marking” the track first at the beginning of the track with Shift/A and then let it play through to the end and pressed Shift/A again so that I can capture the entire 3 min:27sec.
But, it seems to lose either the beginning marker or the end marker so I can’t capture the whole 3 min:27sec
Maybe I’m making it harder than it should be?
Is there an easier way to carve out a track?
Thank you.
