Editing from digital recorder...
I want to edit some sections transferred from a digital voice recorder, when I upload it to Audacity the 40 minute track is shown the length of the Audacity window making it hard to place the cursor to cut out sections…
I cant’t find out how to do this, not knowing what it is called, but how do I expand the track to the form they usually have when I have recorded it in Audacity so there is enough space in the track to see where to place the cursor…
Zooming … http://manual.audacityteam.org/index.php?title=Zooming
See the four buttons on the right of the toolbar …
The little things with “+” and “-” are supposed to be a magnifying glass: “+” is zoom-in , “-” is zoom-out
If you “select” the portion of the track you want to expand then press the button I have coloured green the selection will expand to fit the screen.
Thank you!
I had tried that but it did not seem to work, found with a really big file it takes a while… or edit in small pieces
works great!
