Hi all,
I am about to start editing my first book and am trying to make sure I know enough about the process and have enough of the tools to make it as painless as possible. Can I get feedback on what I think the process should be? I’ve read a lot in the forums and appreciate all and can’t quite seem to find the answer as to how to best go about some of this.
Should I:
apply a low end roll off
set a limiter to catch my peaks
lightly compress… 2:1
set a noise gate at about the level of my breathes to drop them by 10 decibels or so
and then
listen through and individually de-click clicks, bass cut plosives and de-ess sibilance
adjust any timing issues
punch/paste over mouth noise between sentences when necessary
use automation to address any weirdly loud breathes
master:
normalize to -20
set a limiter at -3.5
… and then listen through the whole thing again
What do y’all think? I am able to follow the mastering steps to (so far) consistently produce audio that passes the ACX checker plug-in, but now that I’m about to embark on the journey of editing and mastering an 8 hour book for the first time that will then go out into the world for all to hear, I’m just trying to make sure I’m setting myself up to be reasonably efficient for a beginner.
