hello
how to select a small portions
ex snap portions bet 0.20 and 0.30
thanks
bonjour
comment selectionner une petite partie
ex " snapshot " portions entre 0.20 et 0.30
merci
hello
thanks
bonjour
merci
Click on the blue waves under the 0.2 mark and drag until you get to 0.3? You can get increased accuracy by magnifying the waves like it looks like you did already. If you need surgical accuracy, you can use the Start and End windows at the bottom of the Audacity screen.
