Edit
Windows 7 – .exe installer
I have exported some music to a folder on desk top and now would like to make changes to this music. When I open this file I can’t undo anything that I did as in edit the first thing to undo is “open” preventing me from undoing anything else. I there a way aroung this? I hope I have explained this clear enough.
Thanks for your help.
Audacity is a great program.
Art
Neither Audacity Projects nor exported stand-alone music files save UNDO. We recommend you export or save several times as you edit. If the computer crashes or you need to go back to an earlier version of your song, you can do that.
Hi Koz
Thanks for the rapid reply. Will take your advise.
Art
