Audacity 2.3.0 on Windows 7.
I’m recording from a tape to Audacity using a Tape recorder with a USB connector, and it seems like that this specific tape was recorded with the wrong speed and in order to listen to it properly I need to reduce the “play at speed bar” to .50.
How can I fix the recording to permanently have it saved with the corrected speed so I can listen to it in any media player without needing to adjust the speed?
Thanks for your help
This a great software, marvelous.
