Edit Metadata drop down menu
Hi Audacity people,
I work for a firm that does video and audio highlights for the NHL. Everyday I use Audacity to edit NHL interviews for the “NHL Live” podcasts. It would be nice if in the “genre” dropdown menu there was a catigory for “sports talk” or “news”.
Thanks,
Ray
If you go to File > Open Metadata Editor … in the dialg box there is a box titled Genres and a button labelled Edit - click on that Edit button and you can add Genres that you require (or delete/change existing entries).
Thank You…I will give it a try.
