I’m using the 30 days trial of the EchoBoy sound effect.
Everything works fine but when I export my project to WAV and listen to it, it’s all dry, without the effects.
In Audacity some VSTs revert to the default setting when applied, which is usually null, (100% dry).
Saving your settings as a preset in the the plugin may cause them to persist, rather than be ignored.
