Echo
Hi everyone. I’m a relative newcomer using audacity and am
Running a school radio program with it. There seems to be a lot of echo when I record. Any tips to help with this!
What does that mean? What are you recording? From the microphone built into your laptop? From a USB mic or USB interface? Etc?
…Sometimes you can get an echo if [u]Software Playthrough[/u] is enabled but sometimes simply turning it off isn’t the best fix.
Also, see if using headphones or earphones makes any difference. :slight_smile:
I hope this helps. :smiley:
