Easier way to move waveform display?
Isn’t there some way I can grab the waveform display and pull it to one side or the other? Finding a particular spot in an Audacity recording seems so cumbersome. You might think you could enter a value into “Audio Position” and have it take you there; in my experience, you’d be wrong. Neither have I found any simple way to move throughout a recording in the doco or in any tutorial, nor in this forum. FWIW, I’m running v 2.3.0.
Thank you.
Try this page in the Manual: https://manual.audacityteam.org/man/navigation_tips.html
