Drums to Audacity
I have a Alesis turbo drum set and I would like to use it with audacity but it doesn’t have a midi port any help?
Audacity is not a MIDI application. (It has some very limited MIDI capabilities).
For recording, you can connect the line or headphone output to line-in on a soundcard (usually blue), or if you have a laptop with no line-in you’ll need a USB audio interface with line-inputs.
But, are you saying the drum doesn’t have MIDI? If it has a USB port, that’s probably USB MIDI. But that’s not going to work with Audacity.
