Hello, thanks for reading this post! My friend just bought 5 XLR Drum Mics, but he doesn’t know how to record from them into audacity. He does have a AMP if that helps, its the ELEVATION EG-10J. Would it maybe possible to get XLR to usb then put them in a hub, I dunno, Any help would be much appreciated!
5 XLR Drum Mics,
What kind of mics are they past the XLR connector? You should get them to post. This is going to drag on forever as we ask you something and you ask them and they tell you…
Hello, thanks for reading this post! My friend just bought 5 XLR Drum Mics, but he doesn’t know how to record from them into audacity. He does have a AMP if that helps, its the ELEVATION EG-10J. Would it maybe possible to get XLR to usb then put them in a hub, I dunno, Any help would be much appreciated! The mics are here, if it helps? http://www.audiomate.co.uk/proddetail.php?prod=AT160
